twisted8
03.23.2009, 04:23 PM
You could also install a UE monoblock to extend the chassis by 30mm or so and that will take care of the wheelie issue. Of course you would also have to acquire a longer custom dogbone to drive the rear diff.
i was looking into getting one of them nut thats almost 100 then another 20 or so for a drive shaft then i still need drive cups. might as well buy a chassis. (unless you havea used one for sale )
im running 60k in the front diff, went up from from what i was running and it is better. maybe programming the mmm and driving a bit more conservatively will help ?
or maybe i should go up on the pinion ? running 19/68 now.
the options are not depleted yet ! i was just looking for some inside info so i head in the rite direction.
