03.24.2009, 03:28 PM
I was going to make one for it... I do need new belts, and the 2.5 and 3.3 use different pulleys and different belts too. I think my other belt is the wrong one (so is my luck). My front belt is just right with no shims, so I guess that I need a new center belt...
I may give the one I have a try...
The only difference between the 2.5 and 3.3 belts is the front and rear belts. The center is the same since it uses the same pulley size. The f/r small pulley went from 15T to 20T IIRC, so a larger belt is necessary.
You might want to just brace the chassis. I know that the belt had a ton of play on mine until I braced the chassis. If you push down on the center belt, you can actually see the chassis flexing.
