UE Supermaxx Addict!
04.24.2009, 07:03 AM
You know what, I was worried about how close the pinion was to the slipper, but I moved the pinion as far onto the shaft as possible...the end of the flat-spot is as far as the pinion would go. I will check the slipper plate really well to see if there is any damage from the pinion hitting it. Thanks for that info, Arct1k!
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
