Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
04.24.2009, 07:03 AM
You know what, I was worried about how close the pinion was to the slipper, but I moved the pinion as far onto the shaft as possible...the end of the flat-spot is as far as the pinion would go. I will check the slipper plate really well to see if there is any damage from the pinion hitting it. Thanks for that info, Arct1k!
-Chad
PM ME IF YOU HAVE THE BELOW:
