Originally Posted by nitrostarter
That battery should only be charged at 5amps anyway. As long as the powersupply can deliver 5amps at 12v then you should be fine.
Sorry but incorrect - It will need 5amps at 25.2V as it is a 6s pack - Assuming charger is 80 effecient then it will draw 5amps * 25.2 / 11.5 * 1/0.8 = 13.7amps...
11.5V as the 12v rail will drop.... In reality this is close the the PSU's limit...
