That battery should only be charged at 5amps anyway. As long as the powersupply can deliver 5amps at 12v then you should be fine.
Sorry but incorrect - It will need 5amps at 25.2V as it is a 6s pack - Assuming charger is 80 effecient then it will draw 5amps * 25.2 / 11.5 * 1/0.8 = 13.7amps...
11.5V as the 12v rail will drop.... In reality this is close the the PSU's limit...
