Originally Posted by starscream
Ya, that was quite a while ago. Time really flies.
I ended up buying another crt.5 and then sold it so I could get a RC10 T4
I really think they need a 12 step program for RC
You have a good point about crawlers. It's a must to have a good motor though. I'm sure a HV or purple feigao motor will have cogging issues.
The 2pole feigaos will lack low end torque. I am using 8+ pole outrunners, between 800-1100kv on 3s lipo and they work very well with the castle escs. I also run a 13.5 novak motor on 2s in a "rock racer" and it has enough control and torque to make it crawler capable. I have a sp 17.5 that I would like to try, but I think the speed may be a bit low. Also have a new hacker 13.5 e40 motor, pretty!
Now I would like to see a decent sensored esc with 3s+ capability in a small footprint capable of 60-80amps cont. And some purpose built sealed can outrunners with high qual materials and a sensor too. Run them sensored only and they would be the ultimate in slow speed control and low speed torque.
