Originally Posted by littlegiant
Thanks for your response. I am intending to use the esc in a monster truck.
Which esc can handle heat better? Same setup (speed, vehicle, motor, cell count... etc)different esc. Which esc will run cooler?
I have only used the SP Esc in a buggy so I have no data for MT use. Both Esc's run about the same heat in the buggy. Personally, I would recommend running 6S in a MT or Truggy so my vote goes to the MMM for this. The SP Esc should be fine if you plan to run a sensored 4S motor though.
