Originally Posted by lincpimp
Get a medusa, and you will not want to run heavy batts in a tc, really throws off the balance and causes handling issues. 1/8 shaft is a good idea, as 48p pinion are not too easy to come by in 5mm bore. Or go to a 32p spur, then the sky is the limit with 5mm bore pinions.
How do you run light batteries in a speed run car?
