MetalMan
MetalMan's Avatar
06.10.2009, 05:19 PM
I have those pinions MM. I would not say that they are that good, the set screws are tiny, and I mean tiny.
I have 3 of the 1521 8mm shaft motors, and the tdr colleted pinion adpaters are the best thing I have found... Or pull the rotor out and have it turned down.
Ah, I forgot about their set screw deal. Does TDR's pinion adapter work with an 8mm shaft? If yes I would be very interested in a link if you would be kind enough to provide one
Found it:
http://www.tdracingrc.com/TD%20Product%20Line.htm
Will he do a custom 8mm shaft size version? They're already decently expensive at $35 so I wouldn't want to spend much more...
