skellyo
skellyo's Avatar
06.16.2009, 10:19 PM
101.9 x 35.5 x 20.3 MM (I got this from Traxxas)
I just measured mine with my calipers and got 102.6mm x 34.3mm x 20.6mm. It is not an exact science to measure the opening though as the plastic flexes a bit if you apply much pressure. Also, the bumpout on the battery door isn't the easiest to figure out where to measure the depth on it.
