I just measured mine with my calipers and got 102.6mm x 34.3mm x 20.6mm. It is not an exact science to measure the opening though as the plastic flexes a bit if you apply much pressure. Also, the bumpout on the battery door isn't the easiest to figure out where to measure the depth on it.
I found the info on the Tra***s site. I am not surprised that the actual specs. are a bit different.
