skellyo
skellyo's Avatar
07.21.2009, 10:02 AM
To do a 2S/3S set up (as 5S), you just need to remove the Flux battery wires, and insert a single pack connector - this will make the flux think it is seeing one pack. Oh, and you'll need a series wiring connector for the packs (or is that parallel???) Check Brians speed calculator page on battery wiring to verify the layout.
You don't need to do anything. Just use a single 2S pack and a single 3S pack and use the existing connectors on the Flux ESC. They'll plug right in and be in series for 5S operation. If you do what you stated to modify the connection, you've just wasted your time since it's the same electrically regardless of where the series connection is.
