JThiessen
JThiessen's Avatar
07.21.2009, 09:52 AM
Originally Posted by fastbaja5b View Post
Yeah I did actually, likely a contributing factor!
Can you run a 3s and a 2s on the Flux? The manual says both pack needs to be equal. I didn't think I could even run a 5000mah and a 5100mah pack or a 28C and a 30C pack, what I interpreted was both packs must be identical.
I was banned by hopmeup on ebay because I left them neutral feedback based on the quality of the product they were selling. Dont base your opinion of A123's on what you got from them - they really are good reliable power. Not as much power as lipo, but likely much more reliable.
To do a 2S/3S set up (as 5S), you just need to remove the Flux battery wires, and insert a single pack connector - this will make the flux think it is seeing one pack. Oh, and you'll need a series wiring connector for the packs (or is that parallel???) Check Brians speed calculator page on battery wiring to verify the layout.
