emaxxnitro
emaxxnitro's Avatar
07.24.2009, 10:36 AM
A larger nitro tank, some al tubing arranged in a zig zag pattern with possibly a fan to blow air over it, and a small pump would work well. As long as it is setup properly a water cooling setup would not be very heavy or very big, but finding a pump that can handle a beating may be a challenge. A car w/s washer pump would be a good choice, they are pretty sturdy, and you could mount it to the side of the nitro tank with some creativity. No sure what voltage to run it on, as they produce a fair amount of volume on 12v. Maybe 6v off a ccbec or something like that. If I get bored I may make something!
you can get a radiator.
and a pump http://www3.towerhobbies.com/cgi-bin...?&I=LXDJR7&P=7
808E
