gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
08.15.2009, 07:44 PM
Buggies are pure track machines. Sure, they'll do okay in bash mode, but you'll want the bigger tires, wider stance (stability), and ground clearance.
Check the forums at RCTech. There's a guy selling two brand new RX8s for $160 each over there!!! I can give you his email if you want, he still has both. Combine that with a used Neu or similar motor and you're all set. I would suggest a used MBX5T for a great basher.
:D
