Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.18.2009, 04:13 PM
the spiral cut diff gears in your lsp are bullet proof if you shim them right i have been useing them for years with no failures
LOL ?
I never have problems with wear, Gone thru many bearings though !
I have problems eating gears when I brake the outside diff case under extreme jumps. I was thinking the straight cut gears would hold up better after the case breaks. The spiral cut gears always get the tore up on the ends.
