the spiral cut diff gears in your lsp are bullet proof if you shim them right i have been useing them for years with no failures
LOL ?
I never have problems with wear, Gone thru many bearings though !
I have problems eating gears when I brake the outside diff case under extreme jumps. I was thinking the straight cut gears would hold up better after the case breaks. The spiral cut gears always get the tore up on the ends.
LOL ?
how often do you servise your bearings?
i went to wala wala cermaics after i had a stock bearing fail and since then i havent ever had a diff fail, mine is used for bashing too
