08.31.2009, 12:23 AM
Originally Posted by Krawlin View Post
No I mean 9/51 is the pinion/spur gear combo I have to run with my current setup. Since I have stock Maxx diffs in it, I have to use a 9 tooth pinion on the motor and 51 tooth spur gear on the center diff. I think the Mugen MBX5-T diff's have a 10/43 pinion/ring tooth count, and I can run a 15 tooth pinion gear on the motor with my 51 tooth spur, so I don't need a tiny 9 tooth pinion on the motor.
yeah, we're on the same page. 9/51 spur/pinion isn't alot of tooth contact. If you're mechanically minded the LST diff swap is pretty easy and could save you lots of $$$.
