Pdelcast
Pdelcast's Avatar
10.16.2009, 01:29 PM
Originally Posted by alport View Post
My throttle trim is at 0. I checked this first. The radio works properly with another esc. But I'll try another radio on this weekend. I'll check the voltage of the receiver wire and let you know.
You can always test the radio by using a receiver battery and plugging a servo into the throttle channel on the receiver. If the servo moves when you move the throttle trigger then the radio is OK and the problem is either ESC or ESC calibration. If the servo doesn't move, then the problem is with TX programming or the receiver channel.
Thanx!
Patrick del Castillo
President, Principle Engineer
