teknorc
11.10.2009, 12:33 PM
Originally Posted by dnrcustoms View Post
Ok, really like the tekno kit for my conversion, but just would like to get a little more feedback from others. I like it because it comes with a machined frame which would replace my cheaper RTR stamped unit. Also, the ability to adjust brakes and use the direct drive or electra-cltch. My main concern is that I have heard I might need a better controler for some reason. I have the dx3s, also does the reciever fit in the box the supply. Any opinions or feedback would be greatly apprecited.
Yeah, the DX3S doesn't do throttle/brake mixing on the 3rd channel. It only does steering mixing. Try the DX3R, M11, or 3PK/4PK radios if you want to do full mixing. The other alternative is to run a Y-splitter for the brake servo, which many do.
The RX is not meant to fit in the radio tray, it goes on top next to the ESC. Some have been able to fit super tiny micro RX's in there, but any time you need access to the wires (like when programming your ESC) it's easier if it's on top. Hope this helps. Thanks.
Tekno RC - Performance Parts
