sikeston34m
sikeston34m's Avatar
12.02.2009, 09:38 PM
How many times have you discharged and charged the pack? At 5C, what is the capacity being put into the pack?
The 1C discharge will basically tell you the real capacity the cell is at, it might be the same as the 5C, but it should be more accurate. Take your time, I'm not in a big rush .
I have around 10 cycles on the packs so far.
At 5C charge rate, I have no idea.
I did do a 1C discharge test (at 4.5 amps), it shows right at 4200mah.
