Originally Posted by sikeston34m
I was just going by mah returned, but it's not accurate since I usually charge at 5 amps or above.
I can do a 1C discharge test and report back. Maybe even do that every so often and log the results. Get some trending results in the works.
Little late tonight, perhaps I'll do that tomorrow night.
How many times have you discharged and charged the pack? At 5C, what is the capacity being put into the pack?
The 1C discharge will basically tell you the real capacity the cell is at, it might be the same as the 5C, but it should be more accurate. Take your time, I'm not in a big rush
