12.14.2009, 09:31 PM
Well, I have 2 m11 radios. One is setup for 75mhz fm and the other is spectrum. I have about 10 specturm rx and maybe 20 fm rx. I also have the am module so I can run am rx if I so desire.
As far as swapping escs or motors, well that is a PITA. So I have alot of motors and escs.
However, if you happen to have a selection of similar vehciles, swapping stuff would not be too bad. Or maybe have a backup roller in case you break alot at once, quicker to swap the elctronics and fix the broken one at a later date?
