View Poll Results: To Share or To Not Share
I share 1 or more esc between rcs 10 26.32%
I share 1 or more motors between rcs 7 18.42%
I share 1 or more receivers between rcs 14 36.84%
I do not share esc between rcs, so don't ask 25 65.79%
I do not share motors between rcs, so don't ask 25 65.79%
I do not share receivers between rcs, so don't ask 22 57.89%
Multiple Choice Poll. Voters: 38. You may not vote on this poll
12.14.2009, 09:31 PM
Well, I have 2 m11 radios. One is setup for 75mhz fm and the other is spectrum. I have about 10 specturm rx and maybe 20 fm rx. I also have the am module so I can run am rx if I so desire.
As far as swapping escs or motors, well that is a PITA. So I have alot of motors and escs.
However, if you happen to have a selection of similar vehciles, swapping stuff would not be too bad. Or maybe have a backup roller in case you break alot at once, quicker to swap the elctronics and fix the broken one at a later date?
