Semi Pro
Semi Pro's Avatar
01.02.2010, 09:52 PM
You can run taller tires! Pretty sure sdp-si had 6mm bore pinion gears over 30t, and just run a lst2 63t plastic spur since the sdp pinions are not hardened.
thats good news, do you have a link
mike is out of the 30 tooth 2speed gears
