this is for my new xxl, linc i was thinking about going with a tdr cullet and mikes 2speed gears but that still puts the top speed under 60mph
You can run taller tires! Pretty sure sdp-si had 6mm bore pinion gears over 30t, and just run a lst2 63t plastic spur since the sdp pinions are not hardened.
