02.04.2006, 09:14 PM
By the way, the answer to this thread is found in the Warrior's manual (http://www.bk-electronics.com/man_warrior_eng.pdf)
For the MICRO-family of controllers programming of timing and motor run-up are possible by use of PC software and programming cable. Controllers have been optimized for partial-load applications through electronic motor timing. In case of mechanical blockage controller reduces current to protect motor. Controller self-tests prevent malfunction and turns controller off.
