RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.29.2006, 02:59 PM
For an xl motor and room to breathe, the 120 amp warrior is the one IMO. The 9920 can handle quite a bit, but the xl motors can also draw a lot of power. the 8xl or higher can get away with the 9920 more easily for sure, but a 7xl with some voltage is indeed pushing the 9920(it is proven to work, but the 12020 is better IMO).
01.29.2006, 11:21 PM
Thanks Mike. That's kinda what I was figuring, but without the amperage rating, or wattage rating to calculate amperage based on the number of cells used, on a specific motor, it's hard to guess what will work safely. At least the Lehner 19xx series does tell you max power it will handle, but those cost too much. I imagine a similarly sized non-Lehner can would dissipate approximately the same wattage, but the thickness of the can and how well the heat transfers from the coils to the can makes a difference. I suppose I could just get the largest amperage available to be safe, but that darn cost factor gets in the way. :)
BTW Mike, would increasing the size of the heatsink on any controller void its warranty? Of couse, if something went wrong as a direct result of the heatsink upgrade, I wouldn't expect to warranty it.
RC-Monster Mike
Site Owner
01.30.2006, 05:36 PM
technically, removing the shrink wrap voids the warranty. BK is pretty fair when it comes to standing by their stuff, though. If the problem was a manufacturing problem, they would likely take care of it.
squeeforever
squeeforever's Avatar
01.30.2006, 07:03 PM
generally bk will warrant anything. i had one i got wet and they replaced it for free!!
01.30.2006, 07:29 PM
Yeah, I would never submit a warranty claim for something that was obviously my fault. A warranty is for defective products, not stupid users. :)
I have a little heatsink "box" that I was planning to use, properly insulated where applicable of course. That way, I can waterproof the ESC without affecting the heat dissipating properties. I'm not planning on going underwater, I just want to protect it against the occasional splash from a shallow puddle or something. Plus, all that extra surface area will keep it cooler, and that's always a good thing.
GriffinRU
02.04.2006, 12:21 AM
Originally Posted by BrianG
OK, 7xl and 9920 it is then!
I wish these BL motors would have more specs other than just the kv rating. At least power consumption would be nice. At least that way you can figure out the current draw for a particular number of cells to achieve 45-50k rpm.
You have Kv, I and R ...
You have all the parameters to calculate power...
And some manufactures even provide efficiency over RPM or load data...
Artur
02.04.2006, 12:55 AM
Artur
Where are the current and resistance (or impedance) ratings? All I see are the number of turns and the kv rating. Sepcifically, the BK Wanderers?
GriffinRU
02.04.2006, 01:07 AM
For feigao motors are on the motor can. I hope you can get the same info from BK as well. If not then it is not difficult to get the trend from feigao/nemesis to BK...
Artur
02.04.2006, 01:34 AM
Feigaos yes, no such luck for BK. The only detailed documents they offer is for series 10, 15, 19, 22, Basic, and Basic XL. The bk-electronics site simply lists the turns and kv ratings. On the "dimensions" page, it does list the max rpm range (80,000 rpm!) and max current (which is 120A for the XLs). Of course that max current will depend on the number of turns.
The best one can hope for is that someone else with deep pockets and a desire to try various motors can vouch for a specific model - but then there are the variables like truck weight and number of cells to consider. You'd think with the popularity BL motors are gaining that manufacturers would list all the specs so consumers could make an educated buying decision.
However, with the help of several people, I think the BK Wanderer 7XL or 8XL are the best bets.
02.04.2006, 09:14 PM
By the way, the answer to this thread is found in the Warrior's manual (http://www.bk-electronics.com/man_warrior_eng.pdf)
For the MICRO-family of controllers programming of timing and motor run-up are possible by use of PC software and programming cable. Controllers have been optimized for partial-load applications through electronic motor timing. In case of mechanical blockage controller reduces current to protect motor. Controller self-tests prevent malfunction and turns controller off.
