UE Supermaxx Addict!
02.08.2010, 10:27 PM
I didn't bend my Mutant, but as long as you do it in the right place, it will be fine. I would use a front skid-plate to figure out where it needs to be bent, then make sure each side of the bend is supported, don't just try to bend it or it will just fold instead of bend right. Make sure a flat edge is across where you want it to bend so that the front section where the bulkheads mount remain flat, and the chassis behind the bend remains flat. In fact, bolt some bulks to the chassis before you bend.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
