Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
01.01.2010, 01:09 PM
yeah... I am thinking it goes a little more than the batteries falling off... I was also wondering about them getting struck from below during a rough run or a hard landing...
coolhandcountry
coolhandcountry's Avatar
01.01.2010, 01:23 PM
But the batteries are higher then skids. It would have to be a major rut.
It is possible though.
Peace!
Country
Help support the
Rc-Monster
Buy here
Kcaz25
Kcaz25's Avatar
01.01.2010, 09:00 PM
Yeah I won't fall off or slide forward, its got zip ties in the front and back keeping it from sliding in a lawn-dart maneuver or landing on the rear skid. You'll be pleased to hear that I won't be bashing like this, just racing where there are no big ruts. Only thing would be landing on another truck's body post which would be really hard to do.
It really helps handling but I still can't wait until I devise my own way to mount up a CD/motor mount and sling the batteries even lower on a proper tier or tray.
SnoopMaxx
SnoopMaxx's Avatar
01.02.2010, 09:34 AM
One of the new 1:10 SC trucks use a battery tray where the battery stands upright ..but I can't find it right now
Morten SnoopMaxx
Never to old to play
c",)
Kcaz25
Kcaz25's Avatar
02.07.2010, 11:08 PM
Super quick mock up ignore the bit holder, its there to balance the rear suspension on the chassis, and the turnbuckle links will be over the top CD plate not under. This is highly accurate though this is it.
ANGRY-ALIEN
02.07.2010, 11:12 PM
looks trick... do you have any shots from above? also... are you ditching FLM Chassis?
Kcaz25
Kcaz25's Avatar
02.07.2010, 11:22 PM
No, and I will get the new cd unit in a few days. And more pics will come tomorrow I have to get a counter sink kit! I haven't decided about the shocks either... LOL I now have 8 Power Strokes and 8 Super shocks. And all the turnbuckles on the truck(6 in all) will be TRX Red Tubes. WB is 15 inches. I have to study for a bible test now! See ya!
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
02.07.2010, 11:29 PM
That DD wing-mount, Mugen MB-X5T wing-stay & XRAY 808 wing (with uber-awesome UE/Supermaxx stickers) sure does look familiar! ;)
Anyway, I really like that layout, it looks great...as well as like it will work extremely well! What material is that chassis made out of?
-Chad
PM ME IF YOU HAVE THE BELOW:
Kcaz25
Kcaz25's Avatar
02.08.2010, 08:40 AM
Thanks guys! Chad you should not only recognize your wing parts but the chassis as well as it is a trimmed HCR Mutant (so its titanium of course) without a top plate sold to me by user 3.3maxx if you look hard you can see the top plate in the back ground. I ditched the top plate for several reasons, the three main reasons are as follows, some of the posts were striped, I really wanted to lay the servo down like a losi truggy and, it really gets in the way when trying to do an electric conversion.
I'm wanting to give it some kick-up as the mutant uses all rear bulks and has no kick-up. I'm thinking I'll put some shims under the bulks to give some suspension kick-up, but that'll still leave the chassis without any kick-up. What do you guys think about bending the chassis alittle and using a front bulk anyway?
Lito after talking with you in another thread you seem to think that the plastic rod ends are a bad idea and that I should use metal. Can you link me to the correct size, I'm going to be using TRX Red Tube turnbuckles and was planning on using Dubro Monster ball links which are much bigger than what you see in the picture above.
Thanks,
Zack
George16
Supermaxx
George16's Avatar
02.08.2010, 09:13 AM
The rod ends are too small, might not give you the stiffness (while allowing some degree of flexibility) and might be prone to breakage. If you want to use rod ends like that, get the thicker ends from Ofna(you can use the shock ends from any 1/8 shocks). They are thicker and more durable. If you have UE's motherlode of shock parts, those rod ends will work.
I pondered about converting my JT truggy to electric before selling it but I got too lazy. You can also make a plate to connect bulkheads to the cd mount instead of using the links.
Here's my old JT truggy. I sold it last year.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Kcaz25
Kcaz25's Avatar
Thumbs up 02.08.2010, 11:49 AM
Yessir I've seen your JT truggy before! I love it, Lito! It was one thing that made me want this Mutant. I've heard that the bottom of the chassis where the bulks attach is made for VBS thus has 4mm screw holes, counter sinks all that for 4mm. Is that right? Did you tap your bulks out to 4mm? Don't the bulks attach in different places to the skid/chassis.
If you still had it and converted it you would definently want to minimize the top plate probably to the point to just over the steering. I got this idea from the OFNA Hybrid, the use of turnbuckles. Can you direct me to some metal ones? I've seen the ones at RC4WD. BUT I should have been more clear I was planning on using TRX Red Tube turnbuckles and Dubro Monster ball links to tie bulkhead to CD to bulkhead/steering. I've used the Dubro's for 8 months now on my maxx and never broke one after breaking 10s of the 3.3 spec ones. They are bigger than OFNA. Also I'd like to note that I going to erase the red anodize on the CD plate and secure the top of the screws with another plate made out ot carbon fiber, does that make sense? Kinda like a sandwich: CD plate -- 4 turnbuckle links -- CD plate(carbon fiber). Going to do essentially the same thing where the other ends mounts to the bulks.
As far as the plate goes it would be kinda strange because the CD is at a different level than the bulk tabs.
What do you guys think about kick-up? See above post.
Thanx,
Zack
Chadworkz
Chadworkz's Avatar
02.08.2010, 09:33 PM
I actually have a Mutant-Maxx chassis that has been bent to have kick-up and use front bulkheads in the front, and it works great! You can't use the top-plate anymore after you bend in the kick-up, but you aren't using it anyway, so no problem there.
I like how you chopped off the rear section in order to mount the UE Mono-Block, that's cool!
Also, the JT chassis uses standard bulkheads, not VBS...only the UE VBS version uses VBS.
-Chad
Kcaz25
Kcaz25's Avatar
02.08.2010, 09:53 PM
I saw the better pictures you have and came to think maybe the chassis does have kick-up prior to buying this one. But it doesn't. Did you bend it? If so can you give me tips about it. I don't want to mess it up. I know even titanium doesn't like being bent but the bulkhead will probably give a backbone in that spot.
Anyway, I actually haven't cut the chassis. HEHE
Thanks for the VBS confirmation.
Chadworkz
Chadworkz's Avatar
02.08.2010, 10:27 PM
I didn't bend my Mutant, but as long as you do it in the right place, it will be fine. I would use a front skid-plate to figure out where it needs to be bent, then make sure each side of the bend is supported, don't just try to bend it or it will just fold instead of bend right. Make sure a flat edge is across where you want it to bend so that the front section where the bulkheads mount remain flat, and the chassis behind the bend remains flat. In fact, bolt some bulks to the chassis before you bend.
-Chad
Kcaz25
Kcaz25's Avatar
02.08.2010, 11:49 PM
A vise seems like it would be a good tool. Although I don't know if the vise will work after I have bolted it to bulks.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
