Thread: 1/6 bl-lst
Stumpjumper
02.10.2010, 01:26 PM
@ magman
I didnīt just move it back I turned the inside from the on side to the other because I want the motor and gearbox in the middle of the chassie. The wheelbase is now 455mm. Much longer so I can fit FG bodys.
My Custum Parts are:
Alloy Chassie - Prototyp (later I use 6mm Carbon)
Alloy Skid Plate
Alloy Brackets
Alloy Motormount
Alloy ESC Plate
and some more smaller alloy parts
Carbon Tower
Carbon Skid/Bulkplates
Titanium steering linkage conector
Titanium Main Drive Shafts
You donīt have to wonder about sliding batteries. This is the first chassie in alloy and the space of the batteries is a littlebit bigger then I first thougt. On the side of the chassie you see 2 holes for the block. The next chassie is bigger.
If you want more info lock the pics in the link...
thanks - olli
