02.10.2010, 01:26 PM
@ magman
I didn´t just move it back I turned the inside from the on side to the other because I want the motor and gearbox in the middle of the chassie. The wheelbase is now 455mm. Much longer so I can fit FG bodys.
My Custum Parts are:
Alloy Chassie - Prototyp (later I use 6mm Carbon)
Alloy Skid Plate
Alloy Brackets
Alloy Motormount
Alloy ESC Plate
and some more smaller alloy parts
Carbon Tower
Carbon Skid/Bulkplates
Titanium steering linkage conector
Titanium Main Drive Shafts
You don´t have to wonder about sliding batteries. This is the first chassie in alloy and the space of the batteries is a littlebit bigger then I first thougt. On the side of the chassie you see 2 holes for the block. The next chassie is bigger.
If you want more info lock the pics in the link...
thanks - olli
