shaunjohnson
i pwn nitro
shaunjohnson's Avatar
02.21.2010, 04:20 AM
Originally Posted by mistercrash View Post
I want to see how long the stock diffs are going to last. I know the LST diffs last a long long time and don't seem to break a sweat even on 6S. After close to a full year of racing and bashing, my LST diffs only needed new lube recently, the gears and bearings were all in top shape. I want to find out for myself if the stock diffs can last and take abuse like the LST diffs did. I know a lot of people run the stock diffs without problems but I have to test them for myself with my kind of driving.
ive run stock diffs and only ever killed one rear diff but that was a completely different issue that caused that.
driveshaft boot got torn, sliding shaft siezed, pressure put of diff beaering, powdered bearing, ring gear moved and got stripped.
other than that, no troubles, you will need thicker oil in them than you run in the LST diffs though.
i run 500k in the front but that is a tad too thick, i run 5k in the rear and that feels ok.
