Pdelcast
Pdelcast's Avatar
03.09.2010, 05:07 PM
You might be able to fix the issue yourself by using this procedure:
Using a radio that will correctly calibrate the MMM:
1. connect a servo to the throttle channel and power the RX with a battery
2. note the servo positions at max throttle, neutral, and max brake
Then, using the KO Propo radio
2. adjust the end points so that the servo positions match the other setup
Thanx!
Patrick del Castillo
President, Principle Engineer
