Also
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Also - 03.16.2010, 08:52 PM
There may be a very small amount of binding somewhere...suspension, drive-train to cause the electronics to work harder. Or one of the motors just may be a little bit better than the other even though they are technically the same.
Are the esc settings identical as well?
There also could very possibly be a loose connection on the problem truck that is causing a slightly extra drain on the cells. It does not take much to cause this problem.
SUPERMAXX YOUR LIFE.
