Deahttub
03.23.2010, 01:18 PM
Originally Posted by AMorgan View Post
From what I've read on the RX8s, sensorless doesn't really kick in. It's more like a gradation, the more throttle is applied, the more sensorless you are and vice versa. My understanding is it's full sensorless at full throttle and full sensored at 0 throttle and mixed beyond that. My guess is you are severely undergeared and that may be causing some of the issue. With my E-Revo diffs I need around an 18t pinion, with 8ight diffs, it's around a 22.
Well i was geared 21/58, and I recently geared up to 24/58. Do you think that is too agressive? I checked the temp after one run and it was 150ish. I am using a MC center diff in the machine as well....Ran it again today and it was an absoloute beast...it really does handle a bit different...more "stiff"..
