Deahttub
03.23.2010, 01:18 PM
Originally Posted by AMorgan View Post
From what I've read on the RX8s, sensorless doesn't really kick in. It's more like a gradation, the more throttle is applied, the more sensorless you are and vice versa. My understanding is it's full sensorless at full throttle and full sensored at 0 throttle and mixed beyond that. My guess is you are severely undergeared and that may be causing some of the issue. With my E-Revo diffs I need around an 18t pinion, with 8ight diffs, it's around a 22.
Well i was geared 21/58, and I recently geared up to 24/58. Do you think that is too agressive? I checked the temp after one run and it was 150ish. I am using a MC center diff in the machine as well....Ran it again today and it was an absoloute beast...it really does handle a bit different...more "stiff"..
AMorgan
03.23.2010, 01:36 PM
I'd run it through Brian Gs calculator. It sounds like you're in the ballpark (if not maybe a little overgeared). Still running smooth?
Deahttub
03.23.2010, 01:48 PM
yeh it runs smooth....I put it in brian g's calculator and I think it was 39 MPh...(I run 4s)
Deahttub
03.24.2010, 09:50 PM
Figured put what it was....the screws on my center diff backed out on the front side of the diff and dug into the tranny....the diff is fine, but the tranny has some serious grooves in it...looks like im looking for a new tranny....I fixed the center diff and gave it a test drive for one minute in the dark and it's running fine for now....
Sounds like
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Sounds like - 03.24.2010, 10:05 PM
It sounds like you need some "Loctite". If you want to avoid having screws backing out on your rig you might want to start using loctite on your screws to keep them in place during heavy loading. Use the Blue loctite for screws you want to be able to remove regularly, and RED for those that are more permenant.
SUPERMAXX YOUR LIFE.
