bparanoid
04.15.2010, 10:37 AM
Installation almost complete, I would have had it finished last night but ran into a few snags. A few things worth of note:
- The battery strap included with the kit was too short for my application. Following further research on this forum I discovered longer straps are available. My fault. I just ended up buying the Losi straps at my LHS as I didn't want to wait for another order.
- I had a similar issue as IIICJACKIII with sizing of the screws. The original ones removed from the nitro parts were much smaller and a different thread size than the ones needed for Kit (both battery and diff mount) I ended up needing 5 M4 and 1 M3 screws to complete the installation. I figure no problem...so I head off to the LHS for some screws. Well I found out they don't sell screws individually and were only available in a kit at a price of $50.00!. Luckily I had a friend who had a few spares laying around.
Everything else was PERFECT! Thanks Mike and Brian for you assistance with this build. I can't wait to power it up.
Neu-Castle 2200kv
MMM ESC V3
20T pinion gear
2* 2s 5200mah 35C Lipos
Weight 7.2lbs (measured on a bathroom scale)
ID:	8776   Click image for larger version
ID:	8777   Click image for larger version
