nitrostarter
nitrostarter's Avatar
05.13.2010, 10:20 AM
Good batteries would be a must, although I wouldn't expect that it would need much for burst C rating, I would think that the lack of a grip ( rubber on ashphalt vs prop in water) would dramatically lower amp bursts.
There's a reason people mostly run 2p lipo setups. Boat draw far more amps and far higher bursts than a normal land vehicle. There is the added runtime as well, but mainly for safety in the setup and having the available amperage to run some of these setups. 1 change in the prop could drastically spike the amp draw.
Hmm, will it be fiberglass?
Traxxas boat looks cool. Would be nice to see the setup, off to the OSE forums...
Much of the boat community have come to the consensus that this boat will be constructed in ABS for cost reasoning. In the video, you can clearly see the lip of an ABS mono hull.
I love the graphics and layout on that hull.
N. Rustler conversion
