Muggydude
05.15.2010, 07:46 PM
But you can't buy it :( Look on ebay or amain. I alos like the hardirve too. Thanks for the help Chadworkz! Now here's my question for you. Right now I have the MMM 2650kv motor with Turnigy 4s 5000mah 40cs. Think I'll still be able to pop soime wheelies without the first gear? I was alrerady thinking about taking out the 2nd gear because I don't really like the mechanical brakes, the ESC sits way too high (I'm going to move it to where the Brake servo used to sit, and it will shave off some weight. Think my gearing off 16T pinion, 36T spur, and close ratio second gear will be a a good setup? Right now it goes about 45 m.p.h. as it sits.
