Muggydude
05.15.2010, 07:46 PM
But you can't buy it :( Look on ebay or amain. I alos like the hardirve too. Thanks for the help Chadworkz! Now here's my question for you. Right now I have the MMM 2650kv motor with Turnigy 4s 5000mah 40cs. Think I'll still be able to pop soime wheelies without the first gear? I was alrerady thinking about taking out the 2nd gear because I don't really like the mechanical brakes, the ESC sits way too high (I'm going to move it to where the Brake servo used to sit, and it will shave off some weight. Think my gearing off 16T pinion, 36T spur, and close ratio second gear will be a a good setup? Right now it goes about 45 m.p.h. as it sits.
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.15.2010, 11:17 PM
Originally Posted by - SmashBash - View Post
Oh..
okay thanks alot.
Think i found it here http://shop.towerhobbies.com/cgi-bin/wti0001p?&P=WR&I=LXTJB9 :)
Look at the stock status, it's discontinued, so you can not order it, and you can't back-order it, because they don't have any more at all.
First, get rid of that 2650kV and get the 2200kV...the 2650kV is a buggy motor, and does not do well in truck/truggy/monster truck applications...it can actually cause problems, like taking out the ESC. The 2200kV is a truggy motor, producing much more torque and power, and is exactly what you need in a truck/truggy/monster truck.
You DO NOT want to remove 2nd gear, you want to lock the transmission into 2nd gear and then remove the 1st gear components. 16/36 is decent gearing, but you really need to swap that motor for the 2200kV motor. I personally run standard-ratio, but you can run whatever you want...close, standard, wide, whatever (but I recommend standard).
-Chad
PM ME IF YOU HAVE THE BELOW:
