Ryu James
Ryu James's Avatar
05.24.2010, 12:43 AM
Ryu- I see you run 3s. How's the power delivery? We are limited to running 2s, hence the 1509/1Y (3600kv) I'm running. I'm almost having problems with the tires blowing loose. I have some punch control set and have to gentle with the finger at times. I'm wondering if the Enduros will help with traction in a soft/supersoft compound.
i think you always have to use throttle control to prevent spin out. i prefer having more power on tap rather than have the trigger pinned the entire race. some prefer it to have to not use finger input though. honestly though my 2700kv on 3s is not that fast. maybe 40mph. i am geared 15/53. its def faster than stock but not some crazy 60mph slash. if your tires can cut loose now i dont think any tread will prevent that. tires can increase the point at which they do cut loose but if you have enough power to do it now you always will regardless of how sticky the tires. my thoughts anyway. but i have heard the new supersoft compound is the shiznit! thats going to be my next set. i run soft right now.
Jammin SCRT10 Neu 1512 1y
