Cartwheels
06.21.2010, 01:10 AM
Looks to me like you just permanently solder the two short wires together, and attach the long wires to your connector like you normally would. Yes, its a lot of wires - but its where we are at in the technology and avoiding percieved potential problems.
This exaclty what I did. I even CA glued some shrink wrap over the those wires and that whole end of the pack, to keep the wires out of the way. I was even thinking I could carefully pull the wires out of the 2 smaller taps and put them in the 1 bigger 6s tap.
That way I only have to plug in 2 connectors for charging otherwise, it is 4 connections with the Y connector and the main leads!
