JThiessen
JThiessen's Avatar
06.03.2010, 11:14 AM
Looks to me like you just permanently solder the two short wires together, and attach the long wires to your connector like you normally would. Yes, its a lot of wires - but its where we are at in the technology and avoiding percieved potential problems.
I'm REALLY tempted to cut the heat shrink off and see if they are in fact two completely seperate packs.....
Cartwheels
06.21.2010, 01:10 AM
This exaclty what I did. I even CA glued some shrink wrap over the those wires and that whole end of the pack, to keep the wires out of the way. I was even thinking I could carefully pull the wires out of the 2 smaller taps and put them in the 1 bigger 6s tap.
That way I only have to plug in 2 connectors for charging otherwise, it is 4 connections with the Y connector and the main leads!
Mikey007
07.06.2010, 09:31 AM
Just cut open a 6s hyperion ex pack to reconfigure it, and it is indeed two 3s packs.
JThiessen
JThiessen's Avatar
07.06.2010, 10:24 AM
Good to know. Thanks!
