07.01.2010, 05:13 PM
Here are some rough measurements for you- didnt fancy removing the tranny as its well buried andnot an easy thing to take out without dismantling the whole truck:-
6cm wide, 9cm long ( front to back including slipper ) and 7cm tall ( not including motor mounting plate ).
Should give you a rough idea of whether it will fit easily or not, but I reckon it would- mounting tabs either side are about half way up.
