nitrostarter
nitrostarter's Avatar
07.16.2010, 04:21 PM
Aveox is a 4 pole motor right? The vxl esc has an rpm limit, and using a 4 pole motor means the esc is seeing an rpm level 2 times higher than it actually is, so the esc throttles back the motor when you excede that limit. Stick to 2 pole motors with the vxl esc, or upgrade to a better esc like the MMpro.
That is correct Neil!
I've tried running a couple Neu's on a VXL esc and no such luck...
N. Rustler conversion
