07.16.2010, 09:37 AM
Aveox is a 4 pole motor right? The vxl esc has an rpm limit, and using a 4 pole motor means the esc is seeing an rpm level 2 times higher than it actually is, so the esc throttles back the motor when you excede that limit. Stick to 2 pole motors with the vxl esc, or upgrade to a better esc like the MMpro.
billybob
07.16.2010, 10:27 AM
That makes sense....I guess im running the stock motor for now till i get a new ESC..
scarletboa
scarletboa's Avatar
07.16.2010, 02:42 PM
The mamba max pro would be a very good choice for this truck. You could even run sensored motors and go up to 6s with it, given the motor can handle it.
billybob
07.17.2010, 10:27 AM
Thats the one i was planning on getting....Or the Tekin RX8 1/8th scale set up...I havent really swayed either way yet...
scarletboa
scarletboa's Avatar
07.18.2010, 01:53 AM
the rx8 is overkill for this truck and doesn't have some of the nice tuning features that the MMP comes with.another nice bonus is the price. the MMP is much cheaper than the rx8. the only downside of getting the MMP is not being able to run it in truggies.
billybob
07.19.2010, 01:14 PM
I was planning on the MMP but I just purchased a Trug and want something that i can swap back and forth depending on what I want to run on that particular weekend...
nitrostarter
nitrostarter's Avatar
07.16.2010, 04:21 PM
That is correct Neil!
I've tried running a couple Neu's on a VXL esc and no such luck...
N. Rustler conversion
