nuz69
nuz69's Avatar
08.12.2010, 03:23 PM
The endbell screws are exactly the same as on the 1515 motor -- never seen one broken -- ever. Just we used them on both the front and back of the motor to lower costs (the front-endbell screws moutns on the 1515 are really expensive to machine -- lots of time on the CNCs)
It is the same screws of the REAR endbell I meant, the front endbell on the NEU-CC 1515/1y has stronger screws longitudinally mounted. I thought you change the system on the 1:10 scale motors for this reason, sorry.
I broke a motor front endbell with this system (ORION 2300Kv 4 poles), but the motor was hold by the front endbell, if in the HPI chassis the motor is mounted with front and rear fixation they should be no problem...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
