Originally Posted by Pdelcast
The endbell screws are exactly the same as on the 1515 motor -- never seen one broken -- ever. Just we used them on both the front and back of the motor to lower costs (the front-endbell screws moutns on the 1515 are really expensive to machine -- lots of time on the CNCs)
It is the same screws of the REAR endbell I meant, the front endbell on the NEU-CC 1515/1y has stronger screws longitudinally mounted. I thought you change the system on the 1:10 scale motors for this reason, sorry.
I broke a motor front endbell with this system (ORION 2300Kv 4 poles), but the motor was hold by the front endbell, if in the HPI chassis the motor is mounted with front and rear fixation they should be no problem...
